For WC8, I noticed that temp sensor DS18B20 is sensitive to 5V voltage level.
It will not work and will show "faulty" if the voltage is just above 5.00V, Say, it will not work if it will be 5.02V
If the voltage is 4.95V, and below (down to 4V) it works stable, no problems.
So I guess if there is a problem with these sensors, you can lower the voltage and it should work.
I got rid from switching power supply on this board; I use a good one commercial grade 5V power supply (TDK-Lambda), purchased on Digi-Key.
So that I can set this 5V level precisely.
