upstatemike said:
Dean Roddey said:
If the protocol is both complex and under-documented, that doesn't sound terribly optimal
No. This is why I don't count a CQC Stargate plugin as one of the viable options.
I wouldn't say the JDS protocol is complex. It's just not exactly 100% documented. Glen Todd (R.I.P.) who did the HomeSeer plugin had to chase a few things down with JDS and reverse engineer a few other things, but it was definitely do-able. However, it would take a fairly motivated individual, someone with a Stargate to test with, to knock out a CQC driver.
There was an opportunity in the recent past for a CQC driver to pick up a bunch of Stargate users, including myself, who were dissatisfied with HomeSeer. HomeSeer got better, nevertheless a CQC driver would peak my interest.
Upstate- a few more comments:
I think you'd quickly dump HomeRunner after you see what HS/ML can do, or CQC for that matter.
Although I'm a die-hard SG user, Elk is clearly the hottest thing going on right now and the apparent energy/enthusiasm behind it is bound to bring about several years of enhancements and new opportunities for hardware and software interfaces. That alone makes it definitely worth considering.
A CQC Stargate plugin would be the best deal (in terms of investment), but I still think it leaves you vulnerable on phone functions because the JDS phone board is basically obsolete.
I'm not sure why you need a "one-wire" touchscreen, but I still think you can save some serious $ by going with cheap PC's and a 15" touchscreen combo for less that $600 per setup. For example, I use a Dell 153FPT desktop touchscreen for about $200-350 and an HP EPC42 small form factor PC for about $200. Since these are full-function PC setups - not proprietary touchscreens and not limited by Win CE - you can pretty much do anything you can think of with them - ML or CQC, IP Cams, TV tuners, surfing, VR, TTS, etc.
Mark
