Hi folks,
As always in the fall, I start planning my cocooning for the winter months. This year it's going to be getting rid of IR control of all my zoned audio equipment.
I have always been frustrated with IR control. I felt it was cumbersome, awkward and just plain unreliable. My IR zoning was based off an Ocelot + secur16IR, being controlled by Housebot. My zoning was 4 commercial stereo amps. In fact this was why I had to go with zoned IR in the first place, they all use the same remote, so I couldn't use an IR blaster.
The other factor driving my move away from (zoned) IR is that I am also moving off the Ocelot. Ocelot has run it's course and just hasn't kept up with the times. Since moving my HA setup to a diskless & fanless thin PC running Windows and Housebot, the reliability & self contained advantage of the Ocelot has vanished.
My original intent for dumping zoned IR was to replace the Ocelot zoned IR with a dedicated (usb?/ethernet?) zoned IR unit. But I could not find one. Sure there are the Global Cache products, but at $100 for 3 zones, I think it's steep for what it is. + I would still have all the problems of learning, emitters, and other oddities that IR has given me over the years.
I am fairly proficient in electronics, so my next idea was to do a hardware hack directly into my stereo amps. These are 4 line in + radio, 200W amps I picked up a few years ago for about $80 each for the sole purpose of doing whole house audio. My original stumbling block here was that the audio and input selector are rotary and feed input to a microcontroller chip in the amp. However, when I started poking around the other chips in the amp, I discovered a whole new class of audio chips I never knew existed. Audio processing chips.
These audio processing chips come with vol, mute, bass, treble and many come with multiple inputs... up to 4. These chips are controlled by an interface called I2C which is specifically designed for easily controlling chips and circuit design simplicity. It would be very easy for a design to incorporate USB functionality to control the audio processing chip. The total value of the components would easily be less than $50... And that is being very generous.
So my question is this... Why doesn't anyone make an INexpensive 4x4 (at least) audio zone controller? Very much like the Nuvo Simplese, but without the amp, keypad support or IR. Most HA folks have touchscreens, tablets, other controllers already, so the keypads are just a waste. Most HA folks use computer media, media players, internet radio so IR is just a waste.
Either I am way off the mark or I sense some prototyping in my future.
Tim
Tim
