No, that is not a problem, since most those RET actually are behind conditional branch after the TST commands. They don't get executed unless condition met.
If you update the firmware to the new one, you can save a copy of your code with comment, then it may help you remember what did you want each RET doing.
LarrylLix i was thinking of using the GOTO instead on RET thanks
CAI_Support i will have to update,code with comment will help thanks
A common exit can help if you want to add more closing code that is common to all cases.
Commenting only works if you edit elsewhere. The WC8 removes all comments and formatting and the process makes it cumbersome to run trial code testing.
