Thank you Mike.
Yup checked the voltage to be fine.
A while back did lose one phase of electric (underground). 1/2 of the electric went out in the house. Electric company came right away (7 AM on a Sunday morning) and replaced meter with some device which put my electric to one phase. About a week later a crew came over to dig (in the snow) for about 2 days (dug under a tree) and found that the tree roots had separated / broke one of the three electrical wires. I kept the ends as a souvenir. They fixed it and I was good to go.
I did find one issue this time. (which I had nothing to do with). The electric for two 15 AMP circuits (lights and wall power plates) used one common neutral (white) which I had never seen before. The two neutrals (light and outlet) were twisted together in one box to the one neutral coming from the panel. I pulled a new white neutral wire back to the fuse panel (well fished it) such that the two circuits had two black (hot) and two white (neutral). While doing this separated two 2 duplex outlets to two circuits and ran another hot and neutral wire to the panel. (6 wires in the conduit were no issues to run).
I am desoldering the MOV. While grabbing it with tweezers it fell apart. There is also a diode or resistor next to it that looks totally fried and is open right now. Can't tell what it is. Shorted where the MOV was and powered it up. No LED lights yet...thinking though have to replace the diode next to it.
