Is it possible to hook a Leviton/HAI master at one end & then an auxiliary in another location without the traditional 3-way wiring between them?
Similar to Insteon set-up where you simply need a feed at both and the load at one or do you need the traveler?
I want to add virtual 3-ways where there is no existing wiring between switches in a retrofit application
