Updating home incandescent lamps to LED lamps
Might go "out of the box" here.  I didn't really want to automate the under the counter LED lighting but might go with something like this as the footprint is tiny and wouldn't be much noticed under the kitchen counters.
I would just change the SonOff firmware to using Tasmota and use it to switch on the 120VAC LED power supply.
It would be nice too if the OP2 talked to WiFi switches.
Thanks for the pointer to the LED Power supply ( YUNLIGHTS 2pcs LED Transformer LED Power Supply).
Noticed here with the heat and AC power zapping local grid the power changes to the AC causing all of the LED lamps to flicker at 30% dimming.
