apostolakisl
Lou,
Thanks for pointing out the difference in how inputs are driven on the Electronics Salon Rly-2 board (described in your eBay link) from other popular relay boards like those from SainSmart (commonly used with Arduino).
If possible I'd like to avoid is two separate power supplies: one for the WebControl and another for the relay board. What I'd like to know is if the 8-relay board (Electronics Salon) can be powered by the WebControl's 5V output. If all 8 relays were to be activated, do you know if the current draw would exceed what the WebControl's 5V output can supply? The eBay page indicates 800mA with all relays activated. Is it simply a matter of ensuring the WebControl's 9VDC supply can supply sufficient current (say a 1A rating) or will its onboard regulator (I'm assuming it has something onboard to efficiently drop the 9VDC to 5VDC) be overtaxed?
No, CAI can't power the relays. There is no dry contact relay that will work on that little bit of current as far as I have ever seen. There are solid state relays that work with that small amount of power, but these aren't really suitable to switch a real load. I have some solid state relays that only draw a few milliamps but all they switch are Elk zones and only serve the purpose of signaling the Elk, not actually switching anything of substance on/off.
You can use a single wall wart to power both the relay board and the CAI, but you would have to pull the power to the relay board directly from the wall wart, not through the CAI. If the relay board isn't rated at the voltage of the wall wart, then you would need a voltage regulator in between.
