I originally intended on powering my Uplink unit with the built in power board on the P983 enclosure. However, since my current draw needs require an aux power supply, I was thinking about getting one large enough for the aux needs in addition to the Uplink.
Uplink specs its max draw (communicating during alarm) at 2A@12VDC. I ran 18/2 solid wire up to the P983, to feed the power board that was included (P624 I think?)
Will the 18/2 wire suffice to get the Uplink enough of the 12V, or will the voltage drop be too much?
Im estimating about 20' run from where the aux supply would be to where the Uplink unit is housed. I checked a couple voltage drop calcs on the net and they are saying about 11.5V at the Uplink unit. Is that enough to keep it going?
Thanks in advance.
-Chris
Thanks in advance.
-Chris
