I deleted this and recreated here in the appropriate subforum, so I apologize if anyone has already read it. Noob mistake.
I am configring a webcontrol PLC (hardware 2.2.2, firmware version v03.02.17f) to monitor my home when I'm away on a trip this Winter, mainly in case my furnace fails. I've hooked up a DS18B20 temperature sensor as shown in the manual and it appears to read around seven degrees farenheit too high. I see nothing in the documentation about calibration, so I was wondering if either I am doing something wrong or if I simply need to account for the difference in software. If it is typical to have some offset, is it likely to be reasonably consistent? So far I've only had a small temperature window to observe it (63F - 65F). So far I've seen it vary from six to eight degrees high. I am using a 9VDC power supply (measures 9.15 V when powering the controller) rated for 675 mA which I believe is enough since I am driving no outputs. Thanks very much.
