jspoon said:Ross, have you considered a simple 4 or 8 input optocoupler board/kit/assembly that will inteface with your existing breakout board?
All this said, it I wanted to create a optocoupler interface, how should I approach it? Do I find some piece of breadboard or something? What would be the schematic if I wanted to use something like a set of SFH620AA's?
Yes, I have, and my next version of this board will lose the input-conditioning resistors and re-use that space for some optos.
As for how to drive the inputs, a simple opto can be used to pull the WC inputs high. They are not actually TTL, and draw quite low current, so the opto can do this easily.
You then need a resistor to current-limit the LED. This is probably the simplest, cheapest, smallest solution.
I have a lot on my plate at the moment, I doubt I'll have a board ready inside a month or two.
