Wi-Fi might be an option. I would need serial to Ethernet on one side, then Wi-Fi to Ethernet and then Ethernet to serial on the other.RAL said:There are quite a few RS232 to WiFi converters out there. Prices are typically under $100 for each end. You can find some very inexpensive ones on eBay if you are willing to work with the bare circuit boards.
http://www.ebay.com/itm/UART-to-WIFI-Convertor-WIFI-Module-RS232-to-Wireless-kit-400m-Wireless-Control-/251295791857
There are also some RS232 wireless transceivers that operate in the 300/400/800/900 MHz range. Some are bare circuit boards, others are ready to plug and play.
http://www.ebay.com/itm/HC-11-433MHz-CC1101-RF-Wireless-Transceiver-RS232-TTL-/181494611302
http://www.ebay.com/itm/2PCS-433M-RS485-Wireless-Transceiver-Module-DTU-UART-RS232-485-422-RF-Smart-Home-/281167251242
I don't have any first hand experience with any of these. But the price is low enough that it's worth a shot to see how well they work.
ano said:Wi-Fi might be an option. I would need serial to Ethernet on one side, then Wi-Fi to Ethernet and then Ethernet to serial on the other.
I also have found some serial to Bluetooth and back. I don't really care about the technology used if it works.
Maybe something like this: http://www.amazon.com/gp/product/B00R2N6BQ0?redirect=true&pldnSite=1
The problem is more than just cable length, unfortunately. More a problem of getting any cables between the two points. My house is a Territorialpete_c said:Here still using a few extended runs of Cat5E for RS-232.
All of my RS-232 runs today for the Digi Edgeport boxes are using little RS-232 baluns I made up which utilize standard cat5e cables.
The sign is very handy. In my last house I had a giant 3-line color Alpha sign in the kitchen. it was great, but the Omni could drive it. It took lots of programming and CQC to drive it. I had another smaller one in the garage.pete_c said:Ahh....
Yeah I purchased a beta brite sign many many years ago but never could fine a use for it.
I have seen a few Homeseer users that use them.
