JonW said:Where is the outside temperature defined in the OPII panel?
This is a great idea I'm going to convey to my mother in AZ. She doesn't have an HAI panel, but she could at least set some programmed setpoints to chill lower prior to rate hike timeslots.
Just be aware there are two types (well, 3, I guess) of temperature sensors here. The OmniStat can have sensors attached to it. These only give you two total temperatures, indoor and outdoor, with multiple sensors being averaged in each category. The individual sensors cannot be seen by an Omni/Lumina panel.
You can attach external sensors directly to the Omni panel. All sensors connected this way can be used for automation programming by the Omni, as well as the indoor temperature from the OmniStat. I don't know if the outdoor temperature from the OmniStat can be used, I haven't tried that myself.
So you need to think ahead a little about what you want the sensors for. The sensors are all a little pricey from Leviton/HAI.
