I think I just solved my door logging class issue: abandon it!
Leviton says to contact Kwikset and Kwikset/B&D support seems useless on such questions.
Work around:
If user 5 unlocks the door we see (my previous post on manual operations was with user 1):
<N049:152,064
<n049:000,113,005,019,005
Then user 3 locks it (requires user 3 entering code then hitting lock otherwise, user will show as 000 which I guess means system):
<N049:152,064
<n049:000,113,005,018,003
Unlocked by user one (note a one is also appended on actuation via the lever and key, this will be ignored):
<N049:152,064
<n049:000,113,005,019,001
If we let Premise manage the user data, things are just easier!
EDIT: Why door logging doesn't work:
I can request a door logging record, but nothing is returned (this should return user 3):
>N49SS76,3,3
<E000
<N049:152,128,022,145,195,164,010,177,024,186
<X000
However, if I iterate through zzz=0 to zzz=255 for >N49SS76,3,zzz, I obtain the following resutls for record 3. Note that zzz in the working commands below appears to be random (e.g. encrypted). If I rerun my script to iterate through zzz=0 to zzz=255 again, I obtain completely different zzz values. I'm wondering if this is intentional on Kwikset's part or if the VRC0P is not encoding the entire command for some reason?
>N49SS76,3,2
<N049:152,064
<N049:152,128,214,219,134,062,178,093,161,054
<n049:000,076,004,003,007,208,001,004,016,031,012,015,005,005,054,054\
<n049:053,048,050
>N49SS76,3,10
<N049:152,064
<n049:053,048,050
<N049:152,128,053,112,064,040,050,036,180,157
<X000
>N49SS76,3,50
<N049:152,064
<N049:152,128,193,231,191,090,035,216,240,168
<n049:053,048,050
<X000
>N49SS76,3,140
<N049:152,064
<n049:053,048,050
<N049:152,128,245,099,144,142,246,015,187,162
<X000
>N49SS76,3,175
<N049:152,064
<N049:152,128,092,177,019,095,115,043,076,116
<n049:053,048,050
<X000
