I am having a hard time using my multimeter to track down contacts. My home is prewired, and I haven't yet installed a panel.
I have two multimeters (one crappy, one larger nicer one). Both have a continuity test that beeps when there's continuity. Most window contacts are VIP88 sensors, so are normally closed. So I *should* hear a beep when the windows are all closed in a zone, correct?
I got nothing on any wires. Each wire is a pair, so I tested the red and black continuity...
I have read about EOLRs. I don't know whether or not I have EOLRs, but would the presence of EOLRs on the line prevent a continuity test?
-- I tried reading the resistance (range 20, 200, 2k, 20k, 200k 2M and 20M ohms) and saw no difference in value when the window was open, or closed, on any of the wires. The meter would always just say "1".
Do I need to pipe an audio signal through for testing, or go ahead and get an inductive cable tracker?
