I've searched all over and either I'm not using the perfect keywords or I find info that I'm unsure whether it applies to my situation. So here goes...
I'm planning to run some conduit for low voltage/networking wires that will go between floors (basement, 1st floor, 2nd floor, partially finished 3rd floor/unfinished attic). I'm trying to understand the appropriate fire blocking method. I understand there needs to be fire blocking material around the conduit penetration between floors but does there also need to be fire blocking INSIDE the conduit? If so, what use is a conduit anyway since, I would assume, it would negate the perceived benefit of being able to easily fish wires in the future? If there doesn't need to be fire block inside the conduit, then what's the difference between having an open ended conduit running between floors vs an unprotected hole between floors? Seems fire could just as easily spread between floors through conduit (if it starts at one end of the conduit) as it would if it started on one side of a bare hole in the floor plate. I must be missing something. Thanks in advance for any info/explanation.
