Hello All,
I'm trying to monitor my GE Symphony II Generator to determine when it's ON or OFF.
i've got an ELK with a zone already wired to the "Fault" output on the generator, however I would prefer to trigger simply when the generator is running.
I attached the wiring diagram.
Here is the link page 25 shows the connections i'm assuming i'll need to use. It's currently connected to the fault N/O contacts.
If anyone can advise how to monitor the status that would be great. I should note that it does come with a wireless monitor which lights an LED up, however I do not want to rely on that, and prefer the hard-wire directly to the Generator.
Thank you
Thank you
