Breaking WPA2 by forcing nonce reuse
Discovered by Mathy Vanhoef of imec-DistriNet, KU Leuven
Although this paper is made public now, it was already submitted for review on 19 May 2017. After this, only minor changes were made. As a result, the findings in the paper are already several months old.
We discovered serious weaknesses in WPA2, a protocol that secures all modern protected Wi-Fi networks. An attacker within range of a victim can exploit these weaknesses using key reinstallation attacks (KRACKs). Concretely, attackers can use this novel attack technique to read information that was previously assumed to be safely encrypted. This can be abused to steal sensitive information such as credit card numbers, passwords, chat messages, emails, photos, and so on. The attack works against all modern protected Wi-Fi networks. Depending on the network configuration, it is also possible to inject and manipulate data. For example, an attacker might be able to inject ransomware or other malware into websites.
The weaknesses are in the Wi-Fi standard itself, and not in individual products or implementations. Therefore, any correct implementation of WPA2 is likely affected. To prevent the attack, users must update affected products as soon as security updates become available. Note that if your device supports Wi-Fi, it is most likely affected. During our initial research, we discovered ourselves that Android, Linux, Apple, Windows, OpenBSD, MediaTek, Linksys, and others, are all affected by some variant of the attacks. For more information about specific products, consult the database of CERT/CC, or contact your vendor.
The research behind the attack will be presented at the Computer and Communications Security (CCS) conference, and at the Black Hat Europe conference. Our detailed research paper can already be downloaded.
Q&A
Do we now need WPA3?
No, luckily implementations can be patched in a backwards-compatible manner. This means a patched client can still communicate with an unpatched access point, and vice versa. In other words, a patched client or access points sends exactly the same handshake messages as before, and at exactly the same moments in time. However, the security updates will assure a key is only installed once, preventing our attacks. So again, update all your devices once security updates are available.
Should I change my Wi-Fi password?
Changing the password of your Wi-Fi network does not prevent (or mitigate) the attack. So you do not have to update the password of your Wi-Fi network. Instead, you should make sure all your devices are updated, and you should also update the firmware of your router. After updating your router, you can optionally change the Wi-Fi password as an extra precaution.
I'm using WPA2 with only AES. That's also vulnerable?
Yes, that network configuration is also vulnerable. The attack works against both WPA1 and WPA2, against personal and enterprise networks, and against any cipher suite being used (WPA-TKIP, AES-CCMP, and GCMP). So everyone should update their devices to prevent the attack!
You use the word "we" in this website. Who is we?
I use the word "we" because that's what I'm used to writing in papers. In practice, all the work is done by me, with me being Mathy Vanhoef. My awesome supervisor is added under an honorary authorship to the research paper for his excellent general guidance. But all the real work was done on my own. So the author list of academic papers does not represent division of work
Is my device vulnerable?
Probably. Any device that uses Wi-Fi is likely vulnerable. Contact your vendor for more information.
What if there are no security updates for my router?
Our main attack is against the 4-way handshake, and does not exploit access points, but instead targets clients. So it might be that your router does not require security updates. We strongly advise you to contact your vendor for more details. In general though, you can try to mitigate attacks against routers and access points by disabling client functionality (which is for example used in repeater modes) and disabling 802.11r (fast roaming). For ordinary home users, your priority should be updating clients such as laptops and smartphones.
How did you discover these vulnerabilities?
When working on the final (i.e. camera-ready) version of another paper, I was double-checking some claims we made regarding OpenBSD's implementation of the 4-way handshake. In a sense I was slacking off, because I was supposed to be just finishing the paper, instead of staring at code. But there I was, inspecting some code I already read a hundred times, to avoid having to work on the next paragraph. It was at that time that a particular call to ic_set_key caught my attention. This function is called when processing message 3 of the 4-way handshake, and it installs the pairwise key to the driver. While staring at that line of code I thought “Ha. I wonder what happens if that function is called twice”. At the time I (correctly) guessed that calling it twice might reset the nonces associated to the key. And since message 3 can be retransmitted by the Access Point, in practice it might indeed be called twice. “Better make a note of that. Other vendors might also call such a function twice. But let's first finish this paper...”. A few weeks later, after finishing the paper and completing some other work, I investigated this new idea in more detail. And the rest is history.
The 4-way handshake was mathematically proven as secure. How is your attack possible?
The brief answer is that the formal proof does not assure a key is installed once. Instead, it only assures the negotiated key remains secret, and that handshake messages cannot be forged.
The longer answer is mentioned in the introduction of our research paper: our attacks do not violate the security properties proven in formal analysis of the 4-way handshake. In particular, these proofs state that the negotiated encryption key remains private, and that the identity of both the client and Access Point (AP) is confirmed. Our attacks do not leak the encryption key. Additionally, although normal data frames can be forged if TKIP or GCMP is used, an attacker cannot forge handshake messages and hence cannot impersonate the client or AP during handshakes. Therefore, the properties that were proven in formal analysis of the 4-way handshake remain true. However, the problem is that the proofs do not model key installation. Put differently, the formal models did not define when a negotiated key should be installed. In practice, this means the same key can be installed multiple times, thereby resetting nonces and replay counters used by the encryption protocol (e.g. by WPA-TKIP or AES-CCMP).
Some attacks in paper seem hard
We have follow-up work making our attacks (against for example macOS and OpenBSD) significantly more general and easier to execute. So although we agree that some of the attack scenarios in the paper are rather impractical, do not let this fool you into believing key reinstallation attacks cannot be abused in practice.
Are people exploiting this in the wild?
We are not in a position to determine if this vulnerability has been (or is being) actively exploited in the wild. That said, key reinstallations can actually occur spontaneously without an adversary being present! This may for example happen if the last message of a handshake is lost due to background noise, causing a retransmission of the previous message. When processing this retransmitted message, keys may be reinstalled, resulting in nonce reuse just like in a real attack.
Should I temporarily use WEP until my devices are patched?
NO! Keep using WPA2.
Will the Wi-Fi standard be updated to address this?
There seems to be an agreement that the Wi-Fi standard should be updated to explicitly prevent our attacks. These updates likely will be backwards-compatible with older implementations of WPA2. Time will tell whether and how the standard will be updated.
Is the Wi-Fi Alliance also addressing these vulnerabilities?
For those unfamiliar with Wi-Fi, the Wi-Fi Alliance is an organization which certifies that Wi-Fi devices conform to certain standards of interoperability. Among other things, this assures that Wi-Fi products from different vendors work well together.
The Wi-Fi Alliance has a plan to help remedy the discovered vulnerabilities in WPA2. Summarized, they will:
Require testing for this vulnerability within their global certification lab network.
Provide a vulnerability detection tool for use by any Wi-Fi Alliance member (this tool is based on my own detection tool that determines if a device is vulnerable to some of the discovered key reinstallation attacks).
Broadly communicate details on this vulnerability, including remedies, to device vendors. Additionally, vendors are encouraged to work with their solution providers to rapidly integrate any necessary patches.
Communicate the importance for users to ensure they have installed the latest recommended security updates from device manufacturers.
Why did you use match.com as an example in the demonstration video?
Users share a lot of personal information on websites such as match.com. So this example highlights all the sensitive information an attacker can obtain, and hopefully with this example people also better realize the potential (personal) impact. We also hope this example makes people aware of all the information these dating websites may be collecting.
How can these types of bugs be prevented?
We need more rigorous inspections of protocol implementations. This requires help and additional research from the academic community! Together with other researchers, we hope to organize workshop(s) to improve and verify the correctness of security protocol implementations.
Why the domain name krackattacks.com?
First, I'm aware that KRACK attacks is a pleonasm, since KRACK stands for key reinstallation attack and hence already contains the word attack. But the domain name rhymes, so that's why it's used.
Did you get bug bounties for this?
I haven't applied for any bug bounties yet, nor have I received one already.
How does this attack compare to other attacks against WPA2?
This is the first attack against the WPA2 protocol that doesn't rely on password guessing. Indeed, other attacks against WPA2-enabled network are against surrounding technologies such as Wi-Fi Protected Setup (WPS), or are attacks against older standards such as WPA-TKIP. Put differently, none of the existing attacks were against the 4-way handshake or against cipher suites defined in the WPA2 protocol. In contrast, our key reinstallation attack against the 4-way handshake (and against other handshakes) highlights vulnerabilities in the WPA2 protocol itself.
Are other protocols also affected by key reinstallation attacks?
We expect that certain implementations of other protocols may be vulnerable to similar attacks. So it's a good idea to audit security protocol implementations with this attack in mind. However, we consider it unlikely that other protocol standards are affected by similar attacks (or at least so we hope). Nevertheless, it's still a good idea to audit other protocols!
Is there is higher resolution version of the logo?
Yes there is. And a big thank you goes to the person that made the logo!
When did you first notify vendors about the vulnerability?
We sent out notifications to vendors whose products we tested ourselves around 14 July 2017. After communicating with these vendors, we realized how widespread the weaknesses we discovered are (only then did I truly convince myself it was indeed a protocol weaknesses and not a set of implementation bugs). At that point, we decided to let CERT/CC help with the disclosure of the vulnerabilities. In turn, CERT/CC sent out a broad notification to vendors on 28 August 2017.
Why did OpenBSD silently release a patch before the embargo?
OpenBSD was notified of the vulnerability on 15 July 2017, before CERT/CC was involved in the coordination. Quite quickly, Theo de Raadt replied and critiqued the tentative disclosure deadline: “In the open source world, if a person writes a diff and has to sit on it for a month, that is very discouraging”. Note that I wrote and included a suggested diff for OpenBSD already, and that at the time the tentative disclosure deadline was around the end of August. As a compromise, I allowed them to silently patch the vulnerability. In hindsight this was a bad decision, since others might rediscover the vulnerability by inspecting their silent patch. To avoid this problem in the future, OpenBSD will now receive vulnerability notifications closer to the end of an embargo.
So you expect to find other Wi-Fi vulnerabilities?
“I think we're just getting started.” — Master Chief, Halo 1
Q&A
