C
chucklyons
Guest
Maybe I'm excited for nothing, but I have the AB running on my Tilt!! I was meandering around the phone, saw 'enable activex'...hmm...did some surfing, sure enough Win Mobile can run with ActiveX...and it works..even our beloved default button noise comes thru loud and clear! (where is that 'turn off sounds' when you need it!)
I took the sysregister.exe from the Web/ARM/CE300 directory, copied it to the phone. Went to the location I had stored it, fired the .exe away (said yes to the gazillion 'unknown publisher' msgs), hit the default url:86 , and up came the AB...the size is whacked, but it works...even for the TV, Stereo, and the like. Loading can be slow, sometimes..depends on the room and how much you have to load..
I'll throw up a screen snap or two...
Normal 'try at your own risk' caveats apply!
