I am looking to add access control for an exterior gate. I have been reading up on different ways of doing this.
I have a current metal gate that I am planning on re-purposing. I wanted to install a electric strike, with a double cylinder deadbolt latch (need to use a key both sides). I will need a push to exit button out of reach from people outside the gate.
I like the idea of a physical button in the house, but loved the idea of a remote control as well so that wherever we are, we can buzz people in.
I was looking at either doing the access control through an independent system such as a Trine 017tdc-2 or 3 (http://www.trineonline.com/pdfs/instructions/017tdc_018_instructions.pdf). This would allow control via elk and relay, and/or wired button inside house and at device (Push to Exit).
Alternatively, it could be done entirely off the elk with additional devices. Elk-6010 with M1XRFTW? But the 6010 wireless transmitter is not cheap, and probably more buttons than we need.
It goes without saying that power for strike would be independent of the elk's power supply. I am not sure how much mA an electric strike uses and if it is at use, or continuous. I guess battery backup would be good in case of power failure.
I plan to have the latch remain unlocked if the alarm goes off to allow police/fire to access backyard.
Are there advantages of having an independent system from ELK?
Thanks in advance for the help.
