PaulD
Building a new house with large hutch to hold 52" TV & components. The hutch will look like a free standing hutch but will be attached to the wall with no access to back side so all access must be from front or sides. Also, wife insists on doors that close when not in use. I have looked at a variety of rack mounted solution offered by Middle Atlantic but each solution seems to give me a different problem to overcome. Any comments would be appreciated. Here is what I have considered so far...
1) Custom build something using my carpenters - would look nice but I would be locked into size and shelving he builds for me whereas a 19" rack approach provides me more flex to reconfigure in the future as components change out.
2) Slide out and turn racks - several products do this but all are very pricy. The 19" rack approach can use some really nice shelves custom fit to the components but very costly. Another version (not 19" rack) does same thing with shelves but leaves a lot of empty space to see thru into the space with cables behind the cabinet (bad WAF).
3) I looked at a swinging gate style 19" rack but weight and configuration issues in the hutch don't make this very viable.
4) Table size 19" rack - least expensive but poor access to back side or components other than via a side door. If I went this route, I would try to mount the rack on a slide out to give me better access to the rear of components from the side door.
Right now, option 4 is my most likely solution unless someone has some better ideas to offer me.
