No. Each device off the DBH would be assigned an address.
You have 2 options:
The easiest option, as mentioned already, is to install a 2nd DBH at the panel and terminate with a jumper.
The other option is to install the DBH at the panel, but pull the existing DBH wiring off the panel and terminate into the 2nd DBH via crossover. The 2nd DBH would then get terminated into the panel.
