I have an Elk M1G that is setup for 6 partitions (areas), corresponding to two buildings and offices within one building.
Using NextAlarm, the Activity Log shows Arm/Disarm events and there is a column which shows the partition number.
However, NextAlarm attempts to display the overall system status with the message "Your Alarm System is Disarmed." which is incorrect. At this writing, 4 of the 6 partitions are armed.
So, my question is this: Are other central stations more "partition aware" than NextAlarm or is this a standard limitation? Or am I doing something wrong here, for example, should each partition be a separate account? I'd hate to do that as it would obviously make the cost 6x when it's a single panel and single property.
