S Stinger Active Member May 6, 2006 #31 Another unchartered area. Someone mentioned they were going to try and load, but I havent heard an update. Drivers would be your obstacle.
Gemini Active Member May 18, 2006 #32 Ok. I'm lazy and do not want to explore.... could someone please verify my "assumption" on the pin outs for the power supply of a 5055. With the plug locater at 12:00, the negative pin is at 2:00 and the positive pin is at 6:00 and chassis/ground at 10:00. Correct?? Thanks ahead! Update: Nevermind... did my home work and confirmed these connections.
S shaurya Member May 25, 2006 #33 Hello Mr Stinger, Wanted to see how this Touch Screen Computer worked for you so far...Can you please update us all. Is 333Mhz process enough to boot Win2K? Regards, Shaurya
S shaurya Member Jun 18, 2007 #34 For the Intermec 5055B...IIRC, those who bought it has difficulty upgrading the BIOS. Found this site for new BIOS Chip. Note sure if its helpful. Regards, Shaurya
