ANy Mathmaticians out there?
It was way to early this moerning to be looking at your numbers or I was still sleeping... -30 is closer to 0 then -100... so with that said I just got home from work and had a chance to do some math today and I know it dosent sound right but the math works out to
Code:
%	uV	dBm
0	2.238721	-100.0000005
10	707.7219279	-50.00274696
20	1415.443856	-43.98214705
30	2123.165784	-40.46032187
40	2830.887712	-37.96154714
50	3538.60964	-36.02334688
60	4246.331567	-34.43972195
70	4954.053495	-33.10078616
80	5661.775423	-31.94094722
90	6369.497351	-30.91789677
100	7079.458	-29.99999981
.01% =about  0.707721928 uV
so I came up with the following.........
signal level in dB converted to %
ex. -86
10^((-86+107)/20)=11.22018454
(11.22018454/0.707721928)*.01= 0.15853945 aprox percent
so your formula would be
((10^((YOUR NUMBER IN dB+107)/20))/0.707721928)*0.01
Hey, thanks for the help! You should never try to do math like that when you first wake up! Hell, I cant do it when I am fully awake! hahha
Well I thought that was it for a few minutes, I plugged in 30 and it reported 100%. Then when I actually plugged in my variable into the script, I noticed it was spitting out some strange numbers :) I calculated the "center point" between -30 and -100 (-65) and used that to test with.
Here are the 2 lines of code I used to test (This was written in AutoIt script, very similar to VBScript)
$signaldBP=((10^((-65 +107)/20))/0.707721928)*0.01
$signalPercent = Int($signaldB) & "%"
It reports 1%
Knowing that -30 = 100%, and -100 = 0% the halfway point between -30 & -100 is -65.
-30 = 100%
-65 = 50%
-100 = 0%
So in the above 2 lines of code, plugging in -65 should return 50%, but it is returning 1%.
EDIT:
Looking at your chart further, I think I see why, I just don't know how to fix the equasion based on it :)
% uV dBm
0 2.238721 -100.0000005--------------v
10 707.7219279 -50.00274696-------^
-50 Point Jump between line 0 and line 10
20 1415.443856 -43.98214705----------v
100 7079.458 -29.99999981 ------------^Only 20 Data Point jump between like 10 and 80
dB is not a linear world.... so your example of -65 =50% would not be correct, did you move further away and confirm that they are true dB numbers? Or are they doing some sudo averaging and reporting between -30 and -100........ what software are you getting these numbers from? maybe I can play with it.
Its a pretty lengthy AutoIt script, that depends on a lot of other stuff pieced together here :)
Yes, I did move the WiFi device closer and further from the router.
If I move it just 2 feet away, the db drops to just -38 (just 8 points) but the percentage from the script above drops all the way down to 2%.
As mentioned, I wish I would have never even mentioned the dB thing :o as I just want a liniar scale that shows 0 to 100% for values from -100 to -30.
a linear equation would be y = (10/7) * (x + 100)
for x = -100, y = 0
for x = -30, y = 100
Cool, that did it! Thank you very much! I just had to put a check in if >100 then = 100 as I was rarely gettng 101% and such when I was on top of the wireless router. This basically is for my CarPC skin, but I use the same interface on the touchscreens in the house. The front end is Road Runner, and has a COM interface, so bidirectional communication between Road Runner and Home Seer is a snap. So something as simple as If SignalStrength < 10 then HS_Send ("NetworkProblem"), which can then have HS speak something like "Network problems, please check the router" or trigger any type of event.
Here is a capture just to let you guys know what this was all for :)
(The labels at the top for city and such are empty, as I do not have the GPS hooked up to this PC, as those labels will be removed for the 'House skin" :) )
Ah, good ol' Road Runner
Are you going to release your new skin? :)
PS - Ever since my work blocked MP3car on the firewall my life has been incomplete :( Sucks, because it was auto-blocked just because it has mp3 in the site name
- Snyper Bob :)
Nice job Delicious!! :)
Sorry John, I got hung up on the dB thing also.
FYI, there actually IS a How-To on doing this HERE, (linear equation part) though one would not guess that would be of any help with that title.
Glad you got it working.
Yes, RR has become multi purpose for me, perfect for in the car, perfect front end for Home seer in the house.
Yea, I will be releasing the new skin in a couple of weeks or so. It has been coundless hours of work trying to get it all together. You can read about it in the DigitalFX thread. Warning: The thread is now the longest thread on MP3Car, at just over 3,000 posts! So plan for some serious reading LOL
