Hi,
I've been looking into specs and regulations for smoke detectors and have noticed that although it is not a regulation in my area, the general consensus/recommendations is to run 18 gauge fire-rated cable for smoke detectors. However, I have yet to find anyone who could give me a logical explanation why different jurisdictions have adopted 18g as a standard.
I understand the need for fire-rated cabling; the last thing you want is a fire disabling the cable prior to the detector tripping. However, what I don't get is why the thicker wire. From a purely technical/electrical perspective, 22g would work perfectly fine. For that matter, even 24g would work fine, with the only exception being that most detectors are designed with terminals that accept 18-22g wiring. The only thing I can think of is that someone figured that 18g would take longer to burn/melt in the case of a fire. However, wouldn't that have more to do with the fire-proofing rather than the wire itself? Given the same specs for fire/heat resistance on the wire, wouldn't 22g be sufficient?
Does anyone have any logical explanations why fire wire is generally accepted to be thicker?
Just curious.....
Eric
Just curious.....
Eric
