I bet this is an easy answer but I am confused by the installation manual for the Aprilaire 8870. just started connecting my thermostats tonight. I have everything working in standalone mode with 5 wires to thermostat including "C" wire and RC/RH - R jumpered. The manual seems to say that if connecting to a automation system, which I assume means the 8811 then you should not connect the "C" or the "R" wires. When I connect the 8811 (powered of course) and disconnect the "C"and "R" I have no visible display on the 8870.
Are the "C" and "R" wires supposed to still be connected to the 8870 while the 8811 is attached?
Also, is there a way to have the display stay lit all the time?
robolo
robolo
