[Article] How to interface a wireless doorbell with the Elk M1
electron
Administrator
Staff member
[SIZE= 18pt][/SIZE][SIZE= 14pt]Products you'll need:[/SIZE]
  • Elk M1 Gold or any alarm/automation panel that supports analog zone (I will give instructions for Elk M1 Gold, as this is the one I only have)
  • A very long two-conductor wire -- like a speaker wire (you'll want something much longer than you need -- for example: you'll want a 25' wire even though you're going for a 15' wire)
  • Any wireless doorbell -- perferably battery operated (why would you want to go with A/C while you can go with a battery-operated wireless doorbell when the electricity goes out?) I've chosen a $15 Heath Zenith wireless doorbell, bought from Home Depot. Don't forget the C-type batteries.
  • Wire Nuts (easier than having to solder two wires together)
  • Multi-purpose screw driver (even though you can use individual screw drivers, it helps to keep al the screw heads in one place -- different sizes of flat heads, Philip heads, etc.)
[SIZE= 14pt][/SIZE]
Click here to view the article
