I have a normal gas water heater. I'd like to automate it so that it can be taken offline when no one is home. I know the best idea is to replace it with a tankless but I'm not quite ready to do that.
So are there any electronic thermostats for gas water heaters that can be controlled externally?
The only one I have been able to find is this Sears/Honeywell combination but I can't find any information on the control unit itself.
It might not be possible to retrofit something like that onto a standard water heater depending on how it is deigned.
The other idea I had was to put an electronic valve on the line from the control to the burner so that the pilot would remain lit but the burner would never fire unless the valve was open. But I am not sure if this would somehow cause damage to the thermostat/control unit.
If anyone has experiences doing this let me know.
Thanks.
Thanks.
