I was thinking of using 1 of my spare boards to record voltages for battery load tests. The problem is the AIP's are only 10 volt. The batteries I need to test are 24V and 36V. A voltage divider will change voltage as the battery voltage drops and create a slow error that will exist all the way thru the test. So what are some thoughts on the best way to accomplish this?
