I was not really looking for Power conditioning. I just want a cheap, silent, UPS system that will run my entire home theater for hours and hours during a power failure.
It's called a generator
Brian
Do you have a link to the ones that are cheap and silent?
You can save some on the UPS because as stated above you only need battery power for a couple of minutes until the generator starts. What do you consider cheap?? Most of the generators start at $2K plus installation.
Most of the generators I've been looking at are around 65-72db which isn't too bad depending on where you have to place it. I've been looking at 2 different ones the
Guardian 7kw and the
Guardian 16kw (whole house) There are quiet kits available and a buddy of mine in the commercial side has used high tech car audio matting to reduce it even further. You have to know what you are doing here because of the heat generated inside the box.
I currently have a gas portable Honda EU3000IS that I use but there is no automatic startup or circuit switching.
Dave
