[Blogs] The Nexus Technoblog - Russound ST2
Status
Not open for further replies.
CT Droid
CT Bot
I finally found a ST2 (dual AM-FM) for a good price and pulled the trigger.
Installation was fairly easy but there are a few gotcha's to keep in mind. First off when you integrate with a CAM6.6 you need to configure the two sources on the CAM as perephial. You then physically attach the ST2's outputs to those two source inputs on the CAM. Don't forget to connect the CAT5/6 control cable betwrrn the 2 units. Now the piece that I missed at first is that on the ST2 you have to configure it with the sources it is targeting on the CAM. Its all detailed in the instructions but its not something I expected.
Once I made that change I updated my CasaTunes software and I was off to the races! Now I need to install a decent outdoor FM ant and I am golden!
Status
