[Blogs] Three Roberts - 2 1/2 miles of wire
Status
Not open for further replies.
CT Droid
CT Bot
The electricians are done with the 3rd floor so time to run some wire. Here is the stockpile before we started. It totals about 2 1/2 miles. I'm using different colored Cat5e so that runs to the same outlet box can be easily identified which wire is which. Also prior to any pulling I've made a wire layout with each wire run numbered. Will label the wire as I go.
For voice I'll run yellow cat5e. For TV I'll run 1 coax RG6 and 3 Cat5e to each location. I figured with available baluns I'll be able to convert any location to HDMI or component if needed. I've got 22/2 wire and grey cat5e for 2 and 4 wire alarm termination respectively. Lastly running 16/4 speaker wire for whole house audio.
Status
