CT Droid
CT Bot
Last weekend with the help of one of the two Roberts we were able to run all the low voltage wiring for the third floor. Here are all the wires terminating in the mechanical room.
Here they all are bundled runing horizontaly away from the line voltage wires.
Here is the vertical run of wires up the chase alongside the fireplace.
There is not a tru attic space as all the rooms extend to the roof rafters, Here the wire bundles begin to branch off through the ceiling space.
We are colocating as many low voltage outlets as possible with line voltage outlets while still keeping the wires away from each other. Here is a colocated midwall height TV outlet with 1 RG6 and 3 Cat5e.
Here is a typical voice/datat outlet alongside a line voltage outlet.
img]http://www.cocoontech.com/forums/index.php?autocom=gallery&req=viewimage&img=260[/img]
