TeleFragger
my house came with a splitter outside... 1 in and 4 out.
only 4 bedrooms had cable
since then I added cable to the basement, garage, kitchen so that wasnt cutting it...
I did not understand cable tv db ratings and how they work... sp basj away...
I thought the splitter meant that it takes the signal down to that db level and didnt know that you loose that amount EACH time!!!!
thus my delema...
I only have 1 tv with digital cable... so my numbers..
I read that typically a house gets 9db coming in. This went to a 4 way splitter for a loss of 7db per leg or 2db at each leg. All great for the beginning..
I put a 2 way splitter in and ran 1 leg to feed that splitter and removed the living room wire from the 4 way and attached it to the 2 way. Cut that wire and ran it to the utility room. then patched it to the other locations. SInce I didnt know how dbs worked..... I pretty much had a mess....
-1.5db for my digital cable line so when it rained or snowed (like now) tv was choppy and horrible....
well I had a few 4 ways tied in downstream causing this issue... I still am not in a great position..
first 2 way for 3.5db loss goes to second one in util room for a total of 7db loss or going from -1.5 to 2db so now tv is alot better...... however I still had to plug everything else in including my cable modem..... so put the 4 ways back in and my cable modem is down to 0db... internet is still great and fast but I am trying to figure out if I need an amplifier....
so my questions now...
1. do I need an amplifier
2. what one do I want
3. where do I want to put it
bad part is that I could just put a big splitter in but they say the bigger the more loss per leg.... well seem the smaller the better than......
thus my delema...
