roussell
Soooo, I'm putting together a Jwilson-style audio distribution with 7 Insignia NS2000 receivers. I know I could use an Ocelot, IRtrans, or other similar pre-built device for IR control but whats the fun in that??
Instead I'd like to build my own - I'd like it to have 8 outputs, be able to learn IR codes and then 'blast them out on 1 or more of the 8 outputs. In investigating the LIRC devices, I noticed that it works by pulsing the DTR line of the serial port to reproduce the IR protocol. It occurred to me that it might be possible to do the same thing with the CAI board digital inputs and outputs. So (specifically directed to CAI) whats the possibility of tying an IR receiver to an input read in the IR codes and then fire them out one of the outputs. If the only place to store the code internally are the 8 variables then it may be a lost cause, but I thought I'd ask, for this project, I'd only need to store one complete set of IR codes since all of the receivers are the same brand.
If it's not possible with this firmware, how about a custom CAI IR control board? You could probably use the same board, with IR-specific firmware.
TIA,
Terry
TIA,
Terry
