I have 4 ceiling fans that I need to add lighting controls for.
Right now they are simply on/off switches, with fan/lighting controlled at the fan.
If I wanted to switch these to a HA controlled elements, what is the first step I need to take?
I'm assuming since they are single switch controlled, do I need to buy Different Fans if I want to be able to conrol the Fan and Light separately (And in conjunction, run an extra set of power lines to the switch?)
My current thoughts are to go with the OmniProII and a UPB based lighting system.
Are there currently any UPB based Modules I can use to control Lighting/Fan control on separate switches (Or dimmers)?
