archstenton
I'm trying to find a compact motion detector to trigger exterior lighting. Old house I used a RAB Smart box which liked a lot. Problem it runs on line voltage, and this time I want to mount the sensor about a 100 ft from the house on mail box column at the street. It was much easier running conduit and wire for low voltage DC application.
The only thing I've found to date I like is the
Optex FIT-AM,
FIgured I'd get an ELK-960 relay module to set the duration of lights to stay on. Of course, then figured don't want the lights on during the day, so figured I'll put some Digital timer switch on the 120v lighting side to work from like dusk to dawn or something.
Does anyone know of any other compact motion sensors rated for exterior use that doesn't look like a prop from War of the Worlds? I don't have any problems with the Optex, just curious if other products available.
Optex FIT-AM,
