Connect PowerHome to Elk using RS232 over IP?
I installed an M1XEP tonight. It seems to be working fine. I can connect to it using ElkRP, and I can pull up the web pages served by it and control the system. But when I try to connect PH to it, it does not work. I changed the Setup->Controllers and changed my Elk from a Mlk M1 Gold (Serial) to an Elk M1 Gold (Ethernet). I then went to the settings on that same page and entered in the IP address and port that the XEP is running on. Well, every time I try to connect to it with PH, I get an error message: "The Elk M1 ELK Zone Status Request did not return properly. Commands will not be transmitted."
So, what did I miss?
