Has anyone ever connected a HMI panel to an Elk M1 gold, or know of anyone who has. The reason for this questions is I replaced a PLC based automation system and an Ademco alarm system with an Elk M1 Gold. I would like to use the Maple Systems HMI I currently have to display parameters in the M1 Gold.
I know I cannot connect these devices directly, because the HMI does not have address registers the M1 can write to.
I was thinking of using a Triangle Research PLC in between the M1 and the HMI, but I would have to write code for the PLC to receive data from the M1 gold and write it to memory location, that I then could display on the HMI.
I was wondering if there may be a device on the market that would allow the direct connection of the M1 and the HMI that would work with limited programming.
