EmagSamurai
I'm not sure how many of you guys frequent AVS as well, but hopefully posting this question on both forums isn't an internet posting foul. It occurred to me this morning that this was more of a home automation question than a theater question.
I would like to wire up my room exhaust fan to come on automatically when either my AVR/PJ or my HVAC is on. I think I figured out how to do it, but I'd like a sanity check. Here's the relay I'd like to use. It seems perfect since the coil is rated 10VDC to 30 VDC so it will handle both the 12 V AVR trigger as well as the 24 V thermostat voltage.
If I use two of these, I think I can connect the coil of one to the AVR/PJ 12V trigger, and the coil of the other to my HVAC thermostat. Then connect the contacts in parallel to supply the fan. Something like this.
Here's the part I'm not too sure about. I think this is how I need to connect the relay to the thermostat (relay coil between C and G on my thermostat).
Anyone know if this is correct? Am I overlooking something? I've found one site that mentions the thermostat controls the fan during cooling, but the heat pump will control the fan during a heat cycle. Is that true? If so, this may not work as I'd hoped although it's unlikely I will want any heat in my theater.
Also, does anyone see any issues with both the HVAC and the AVR/PJ energizing the fan at the same time? Since it's being fed from the same 120 V leg, I can't see that it would be a problem, but it's worth asking.
Thanks in advance!
Thanks in advance!
