Control X10/Ninja camera via ISY-99i or other device
KevinW
I am just about to delve into Insteon/ISY-99i home control and possibly some simple security, and have one little item I need to address. I have several X10 devices (wall switches, light modules, etc.) and know that I can control those via the ISY-99i. But I am looking to the ISY device to go off-PC and have one item left that I haven't found a solution for. I have 4 X10/Ninja robotic cameras that I would like to be able to position remotely without a PC. I have already connected the video output to a Slingbox so I can view the video without a PC, and can power them on and off through the ISY. The cameras are positioned via an X10 RF interface. Under Windows using a CM15A (ActiveHome Pro USB device) or a CM19A (Firecracker) and the x10nets service, you can use the ahcmd command line program to do a sendrf C16 CamGoPosition1. Is there any way to send these commands from the ISY? What about from one of the Insteon controllers (2412N?) Any other Ethernet attached device?
Thanks.
Kevin
