Ok, after struggling with a missing neutral wire I finally got my Cooper Aspire RF z-wave master dimmer working properly. The 3-way switch (accessory dimmer) is also installed, but does not work. I did successfully join it to the network. The manual says that you need to create an association between the dimmer accesory and the master using your z-wave controller. My controller is an Intermatic HA07. Any idea how I do this? I couldn't find anything in the HA07 manual explaining how to do this.
Thanks!
BTW, solved the missing neutral by bringing it up from a power outlet just below ... interior wall so it was easy
-GT
Thanks!
-GT
