I want to detect generator status via digital inputs on my home control system.
I have a Kohler generator with a Kohler G120 automatic transfer switch.
I _COULD_ wire a relay into the 220V in the transfer switch to detect when the house is on generator power.
HOWEVER, it really looks like my transfer switch has contact points for just this purpose. The problem is I can't find any real documentation and I don't want to screw something up.
The transfer switch control board has the following terminals which are documented in the manual have thusly:
ER - Emergency Relay
ERD - Emergency Relay Disconnect
NR - Normal Relay
NRD - Normal Relay Disconnet
GND - Ground
+12V - +12V
At first I thought, COOL, ER & NR close with ground when ever either relay is active. But after actually testing these I found while on normal power there is +12V across ER/GRD, ERD/GRD and V/NC across NR/GRD and NRD/GRD. I have not tested while the generator is actually working because that's a PITA in my house to test.
So now I'm not sure what these terminals actually are. I was hoping someone here might actually KNOW. If these terminals are for external CONTROL of the relays I'd have thought I'd see +12V or something across NR or NRD while in normal operation.
Anyone actually know for sure?
NR - Normal Relay
GND - Ground
+12V - +12V
