I just bought a middle atlantic rack from craigslist. This is my first rack and I really like it, but I'm searching for a cheap solution to monitor temperature (and display temp within my home automation program) and trigger fans.
First idea so far: find an rs232 temperature sensor that can send a temp as ascii text. Write code to trigger the fans using relays and a weeder i/o board or the GC-100-12 relay contacts plus a power supply. Any such temp sensor out there that is <$50? RS232 output would be very neat. Once the fan is hooked up in this manner, I could also switch the fan on when my receiver has been on for more than x hours etc...
Second idea: not as versatile, but install one of those temperature switches used for attic fans.
By the way, I'm using Motorola Premise so I can potentially use any rs232 device with a published protocol, but the device must be less than $50. I already have the fan and GC-100-12, power supply and relay.
