Premise [download] WeatherUnderground
  • Thread starter Thread starter chucklyons
  • Start date Start date
Motorola Premise
C
chucklyons
Guest
index.php
File Name: WeatherUnderground
File Submitter: chucklyons
File Submitted: 12 Nov 2013
File Category: Premise
Author: Chuck Lyons
Contact: Chucklyons
Not many modifications - just added the MiniBrowser Valid Class Enumerator - removing it from the MiniBrowser base install.
Modified the SRC locations for WeatherUnderground MiniBrowser images, specifically, the 'Next', 'Previous', and 'Update' images.
No new functionality.
Hi Chuck-
What does this do?
I have a hybrid HAL/Cinemar system plus an Oregon Scientific Wireless Weather station that connnects to my PC via serial to USB splitter and use Weatherview
http://www.weatherview32.com/
to access it remotely. For weather other places I use WeatherUnder ground.
Is this an interface?
bob
Bob...welcome to the Premise Forums
Yes, mine is simply the browser interface (123's minibrowser) for 123's WeatherUnderground module. This can be used for a specific location or presumably your own if your system is tied to the WU.
In my latest version the temperature is wrapped in a div, so when an update/change occurs, the UI reflects the change without a refresh.
For a setup like yours, and one I used when I had a WeatherHawk, is the Virtual Weather module, which should be one of the download files. If its not there let me know and I can upload it
Chuck,
I've got this working with PremiseMetro (at least basic display of temp and forecast).  Do you have higher res versions of the weather icon's available?
I'll send you what I have. Any preferred resolution?
Note: Unless I roll my own, I typically buy distributable images from a number of sources. These will be from one of those sources
I'm pretty sure it's not the same group.  If it is, I agree with you.  Bill Ayers and his friends are despicable.
Similar threads
C
Replies
Views
999
chucklyons
C
C
Replies
Views
1K
chucklyons
C
C
Replies
2
Views
2K
chucklyons
C
C
Replies
2
Views
1K
