CAI_Support
What would be the best name to call those four DS2438 current measurement?
Each DS2438 has a current measurement register to read in the current value. What do you like to see that being called in PLC?
We have DS2438 chip support code working now, with a lot of changes to 1-wire bus code. DS2438 has much higher accuracy than DS18B20, so that user can read 0.1 degree change instead of 0.5 degree change in DS18B20.
DS2438 has a 10V analog input, overlap in memory location with DS2450 storage space, that means if using DS2438, do not use DS2450 at the same bus. In our test, DS2438 is a lot tolerable to noise than DS2450.
We have not implemented the functions to read CCA and DCA registers, or reset them. We will add those support later, after some beta testing with voltage and current first.
