Here is what you should receive back from the M1 on an unarmed system:
Request to M1 -- 06as0066 //Make sure you have a carriage return at the end of the string
Reply from M1 -- 1EAS000000001111111100000000000E
Explaination from the M1 ASCII Protocol Document which is downloadable from ELK:
Arming Status Request (as)
06 – Length as hex
as – Request arming status
00 – future use
CC – Checksum
Example: 06as0066(CR-LF) Request Arming status
The control panel responds to this message with an Arming Status Report
Reply Arming Status Report Data (AS)
1E – Length as hex
AS – Reply with zone definition data
S[8] - Array of 8 area armed status.
U[8] - Array of 8 area arm up state.
A[8] - Array of 8 area alarm state.
00 – future use, M1 Version 4.11 and later, contains the first found Exit time if U[x] = ‘3’ or Entrance time if A[x] = ‘1’ as two digits hex in seconds.
CC – Checksum
Example: 1EAS100000004000000030000000000E Area 1 is armed away, and the area is in full fire alarm.
Example: 1EAS1000000031111111000000000902 Exit time set to 9 seconds.
If the control’s area status changes, this message will be sent if Global Option “Transmit Keypad Keys” is enabled.
“S” 8-character array field, represents the arming status of partitions 1-8. The leftmost “S” is Area 1. Each area or partition field can contain one of the following ASCII values:
‘0’ Disarmed
‘1’ Armed Away
‘2’ Armed Stay
‘3’ Armed Stay Instant
‘4’ Armed to Night
‘5’ Armed to Night Instant
‘6’ Armed to Vacation
“U” 8-character array field, represents the arm up state of partitions 1-8. The leftmost “U” is Area 1. Each area or partition field can contain one of the following ASCII values:
‘0’ Not Ready To Arm
‘1’ Ready To Arm
‘2’ Ready To Arm, but a zone is violated and can be Force Armed.
‘3’ Armed with Exit Timer working
‘4’ Armed Fully
‘5’ Force Armed with a force arm zone violated
‘6’ Armed with a bypass
“A” 8-character array field, represents the current alarm state of partitions 1-8. The leftmost “A” is
‘0’ No Alarm Active
‘1’ Entrance Delay is Active
‘2’ Alarm Abort Delay Active
‘3’ to ‘B’ Area is in Full Alarm, see ASCII alarm table values below:
FireAlarm = ‘3’,
MedicalAlarm = ‘4’,
PoliceAlarm = ‘5’,
BurglarAlarm = ‘6’,
Aux1Alarm = ‘7’,
Aux2Alarm = ‘8’,
Aux3Alarm = ‘9’, //not used
Aux4Alarm = ‘:’, //not used
CarbonMonoxideAlarm = ‘;’,
EmergencyAlarm = ‘<’,
FreezeAlarm= ‘=’,
GasAlarm = ‘>’,
HeatAlarm = ‘?’,
WaterAlarm = ‘@’,
FireSupervisory = ‘A’,
VerifyFire = ‘B’,
