Elk M1 Gold Rebooting
heffneil
I have noticed 3 times in a few months that in the logs of me Elk M1 that it seems to restart. I notice 2 things: Home Assistant alerts me it has lost connectivity to the Elk and I hear an audible beep on one or more keypads. The logs on the elk show
1367= SYSTEM START UP
1353 = DIALER AUTO TEST
This happened on 9/29, 11/25 and 12/3
Any thoughts on what might be causing this?
Is the backup battery connected and in good health? If not, perhaps some voltage fluctuations in the power are causing the system to reboot randomly.
Power supply and/or battery are my first thoughts as well. I've seen some very bizarre things happen when power is flakey.
I can't remember all the terminology, but things like keypads plug into a daisy chained bus with a phone-type connector. I've had luck in the past with aerosol electrical contact cleaner on those connections. Also make sure your grounds are common and correct.
