Hi,
After 11 years, my old Lutron HWI system bit the dust and I recently had a new Illuminations processor installed. Since the new Lutron processor has Ethernet built-in, it has freed up an RS232 port which I'd now like to connect to my Elk M1. The purpose is to have the Elk send serial strings to a phantom keypad in Lutron and thus have lighting respond to specific security events.
I've read through the Elk manual again, and while it references the ability to use RS232 to control lighting and other peripherals, it doesn't seem to have much as to how this is accomplished. I've also searched this forum, and again, while there are references to doing this, I'm just not getting it as to how to accomplish this.
So, I submit two (admittedly very basic) Elk M1 questions:
Q1: Which port on the M1 do I use to output commands? Is there more than one choice?
Q2: How do I program the M1 to send a specific ASCII string? I have the latest ElkRP2 software installed and running, but it's not apparent to me where one would define the command strings.
FWIW, I do understand the format of the commands that Lutron is looking for, as I got an iRule setup working previously. I just need to figure out how to send a simple ASCII string out an Elk M1 serial port under programmatic command.
Help, Mr. Wizard!!
Bryan
Help, Mr. Wizard!!
Bryan
